programmer chip compatability
Ricardoco
I have a velleman 8048 programmer with 8pin,14pin,18pin and 28pin 300mil dil sockets but there is no documentation including the 28pin dip socket can anyone shed any light on which chips will be compatable an what the criteria is for compatability thankyou :D :D
Any serially programmed PIC's in that package!, the one I mostly use is the 16F876, but they all use the same connections for programming in the same package.
The supported chips should be listed in the programmer software, it's mostly that (rather than the hardware) which limits the PIC's you can program.
Ahhh
thanks nigel, hmmm does that mean that if i wanted to program a 40pin chip for example i could rig up a circuit to piggy back the original circuit with a 40 pin socket on it?
Re: Ahhh
Yes you could, a 16F876 (28 pin) and a 16F877 (40 pin) are just versions of the same chip. You just need to make sure you connect the correct pins.
