Pspice to LTspice igbt model
I haven't been diligent enough to read the tutorials yet but all I did was .include the subcircuit definition in my schematic and put the name of the included part in the value field for the nigbt symbol on my schematic and leave all other fields blank. As long as the names match and the include is in the same directory as your schematic, or you put the path to it in the .include command, it works. I've been playing with the .spi models offered by International Rectifier and others with no problems, by doing it like this.
Here's an example of a 600 or 1200V 50A half bridge, excuse the errors, it's just a lashup to illustrate the point...
Save this as a .asc file along with the appropriate .spi files from IR (available as spice.zip from their website with most popular devices included).
Version 4
SHEET 1 1452 908
WIRE -5152 -20224 -5280 -20224
WIRE -5008 -20224 -5152 -20224
WIRE -4608 -20224 -5008 -20224
WIRE -4528 -20224 -4608 -20224
WIRE -4448 -20224 -4528 -20224
WIRE -4368 -20224 -4448 -20224
WIRE -4336 -20224 -4368 -20224
WIRE -4096 -20224 -4256 -20224
WIRE -4032 -20224 -4096 -20224
WIRE -4608 -20208 -4608 -20224
WIRE -4528 -20144 -4528 -20224
WIRE -4448 -20144 -4448 -20224
WIRE -5008 -20032 -5008 -20160
WIRE -4896 -20032 -5008 -20032
WIRE -4848 -20032 -4896 -20032
WIRE -5472 -20016 -5504 -20016
WIRE -5392 -20016 -5408 -20016
WIRE -4528 -20016 -4528 -20064
WIRE -4448 -20016 -4448 -20064
WIRE -4448 -20016 -4528 -20016
WIRE -4608 -20000 -4608 -20016
WIRE -4592 -20000 -4608 -20000
WIRE -4528 -20000 -4528 -20016
WIRE -4368 -20000 -4368 -20224
WIRE -4096 -20000 -4096 -20224
WIRE -5280 -19984 -5280 -20224
WIRE -4848 -19952 -4896 -19952
WIRE -4528 -19936 -4528 -20000
WIRE -5008 -19920 -5008 -20032
WIRE -4896 -19920 -4896 -19952
WIRE -5504 -19904 -5504 -20016
WIRE -5488 -19904 -5504 -19904
WIRE -5392 -19904 -5392 -20016
WIRE -5392 -19904 -5408 -19904
WIRE -5328 -19904 -5392 -19904
WIRE -5504 -19888 -5504 -19904
WIRE -5152 -19856 -5152 -20224
WIRE -5008 -19856 -5152 -19856
WIRE -4896 -19856 -5008 -19856
WIRE -4032 -19824 -4032 -20224
WIRE -5504 -19792 -5504 -19808
WIRE -5440 -19792 -5504 -19792
WIRE -5392 -19792 -5392 -19824
WIRE -5392 -19792 -5440 -19792
WIRE -5280 -19792 -5280 -19888
WIRE -5280 -19792 -5392 -19792
WIRE -5008 -19792 -5280 -19792
WIRE -4896 -19792 -5008 -19792
WIRE -4336 -19792 -4896 -19792
WIRE -4240 -19792 -4256 -19792
WIRE -4096 -19792 -4096 -19920
WIRE -4096 -19792 -4160 -19792
WIRE -5440 -19712 -5440 -19792
WIRE -5008 -19696 -5008 -19792
WIRE -4896 -19696 -4896 -19792
WIRE -4096 -19600 -4096 -19792
WIRE -4896 -19568 -4896 -19632
WIRE -4848 -19568 -4896 -19568
WIRE -5280 -19536 -5280 -19792
WIRE -4528 -19504 -4528 -19872
WIRE -4528 -19504 -4544 -19504
WIRE -4448 -19504 -4528 -19504
WIRE -5008 -19488 -5008 -19632
WIRE -4896 -19488 -5008 -19488
WIRE -4848 -19488 -4896 -19488
WIRE -5488 -19456 -5504 -19456
WIRE -5392 -19456 -5408 -19456
WIRE -5328 -19456 -5392 -19456
WIRE -4528 -19456 -4528 -19504
WIRE -4448 -19456 -4448 -19504
WIRE -5504 -19440 -5504 -19456
WIRE -4608 -19440 -4608 -19456
WIRE -5008 -19392 -5008 -19488
WIRE -5504 -19328 -5504 -19360
WIRE -5392 -19328 -5392 -19376
WIRE -5392 -19328 -5504 -19328
WIRE -5280 -19328 -5280 -19440
WIRE -5280 -19328 -5392 -19328
WIRE -5008 -19328 -5280 -19328
WIRE -4608 -19328 -5008 -19328
WIRE -4528 -19328 -4528 -19376
WIRE -4528 -19328 -4608 -19328
WIRE -4448 -19328 -4448 -19376
WIRE -4448 -19328 -4528 -19328
WIRE -4368 -19328 -4368 -19856
WIRE -4368 -19328 -4448 -19328
WIRE -4336 -19328 -4368 -19328
WIRE -4096 -19328 -4096 -19520
WIRE -4096 -19328 -4256 -19328
WIRE -4032 -19328 -4032 -19760
WIRE -4032 -19328 -4096 -19328
FLAG -5440 -19712 0
SYMBOL ind -4352 -19776 R270
WINDOW 0 32 56 VTop 2
WINDOW 3 5 56 VBottom 2
SYMATTR InstName L3
SYMATTR Value 1500u
SYMATTR SpiceLine Rser=10m
SYMBOL cap -5024 -20224 R0
WINDOW 0 26 19 Left 2
WINDOW 3 24 51 Left 2
SYMATTR InstName C1
SYMATTR Value 10n
SYMATTR SpiceLine Irms=100
SYMBOL voltage -5504 -19904 R0
WINDOW 123 0 0 Left 2
WINDOW 39 0 0 Left 2
WINDOW 3 -73 -375 Left 2
WINDOW 0 -16 55 Left 2
SYMATTR Value PULSE(0 12 0u 100n 100n 12.5u 25u 10000)
SYMATTR InstName V3
SYMBOL voltage -4256 -19792 R270
WINDOW 39 24 44 Left 2
WINDOW 3 -76 -82 VRight 2
SYMATTR Value SINE(0 -300 500 0 0 0 100)
SYMATTR InstName V5
SYMBOL res -5392 -19920 R90
WINDOW 0 62 49 VBottom 2
WINDOW 3 -25 57 VTop 2
SYMATTR InstName R1
SYMATTR Value 2.2
SYMBOL ind -4352 -20208 R270
SYMATTR InstName L4
SYMATTR Value 50n
SYMATTR SpiceLine Rser=1m
SYMBOL ind -4352 -19312 R270
SYMATTR InstName L1
SYMATTR Value 50n
SYMBOL res -5408 -19920 R0
SYMATTR InstName R7
SYMATTR Value 10K
SYMBOL voltage -4096 -19616 R0
WINDOW 3 24 72 Left 2
SYMATTR Value 280
SYMATTR InstName V1
SYMBOL voltage -4096 -20016 R0
SYMATTR Value 280
SYMATTR InstName V8
SYMBOL ind -4864 -19584 R0
WINDOW 3 41 74 Left 2
WINDOW 0 44 43 Left 2
SYMATTR Value 220u
SYMATTR InstName L2
SYMATTR SpiceLine Ipk=10 Rser=0.052 Rpar=25447 Cpar=0
SYMBOL res -4912 -19584 R0
WINDOW 0 -35 32 Left 2
WINDOW 3 -39 3 Left 2
SYMATTR InstName R8
SYMATTR Value 470
SYMBOL ind -4864 -20048 R0
WINDOW 0 53 53 Left 2
WINDOW 3 49 78 Left 2
SYMATTR InstName L5
SYMATTR Value 330u
SYMBOL res -4912 -20048 R0
WINDOW 0 -52 41 Left 2
WINDOW 3 -61 67 Left 2
SYMATTR InstName R9
SYMATTR Value 470
SYMBOL cap -4048 -19824 R0
SYMATTR InstName C4
SYMATTR Value 47u
SYMATTR SpiceLine V=1000 Irms=200 Rser=1m
SYMBOL schottky -4624 -20080 R0
WINDOW 3 -56 -173 Left 2
SYMATTR Value MBR20100CT
SYMATTR InstName D7
SYMATTR Description Diode
SYMATTR Type diode
SYMBOL cap -4544 -19936 R0
SYMATTR InstName C5
SYMATTR Value 1u
SYMATTR SpiceLine V=1000 Irms=1000 Rser=1m
SYMBOL res -4544 -20160 R0
SYMATTR InstName R4
SYMATTR Value 470
SYMBOL res -4544 -19472 R0
WINDOW 3 23 92 Left 2
SYMATTR Value 470
SYMATTR InstName R5
SYMBOL res -4384 -20016 R0
SYMATTR InstName R3
SYMATTR Value 22
SYMBOL cap -4384 -19920 R0
SYMATTR InstName C3
SYMATTR Value 470p
SYMBOL diode -4912 -19920 R0
WINDOW 3 40 30 Left 2
WINDOW 0 -44 40 Left 2
SYMATTR Value MUR460
SYMATTR InstName D3
SYMBOL schottky -4624 -19456 R0
WINDOW 0 43 -17 Left 2
WINDOW 3 -63 156 Left 2
SYMATTR InstName D21
SYMATTR Type diode
SYMBOL voltage -5504 -19456 R0
WINDOW 3 -115 149 Left 2
WINDOW 0 -18 55 Left 2
SYMATTR Value PULSE(0 0 13u 50n 50n 10u 25u 10000)
SYMATTR InstName V2
SYMBOL res -5392 -19472 R90
SYMATTR InstName R11
SYMATTR Value 2.2
SYMBOL res -5408 -19472 R0
SYMATTR InstName R13
SYMATTR Value 10K
SYMBOL Misc\\nigbt -5328 -19984 R0
WINDOW 3 -145 24 Left 2
SYMATTR Value irgp4063dpbf
SYMATTR InstName U1
SYMBOL Misc\\nigbt -5328 -19536 R0
WINDOW 3 -122 -4 Left 2
SYMATTR InstName U2
SYMBOL diode -4992 -19632 R180
WINDOW 0 24 64 Left 2
WINDOW 3 24 0 Left 2
SYMATTR InstName D1
SYMATTR Value UPSC600
SYMBOL diode -4992 -19856 R180
WINDOW 3 46 27 Left 2
SYMATTR InstName D4
SYMBOL ind -4464 -20160 R0
SYMATTR InstName L8
SYMATTR Value 33u
SYMBOL ind -4464 -19472 R0
SYMATTR InstName L9
SYMATTR Value 33u
SYMBOL schottky -4624 -20144 R0
WINDOW 3 -59 -109 Left 2
SYMATTR InstName D2
SYMATTR Type diode
SYMBOL schottky -4624 -20208 R0
WINDOW 3 -55 -42 Left 2
SYMATTR InstName D5
SYMATTR Type diode
SYMBOL schottky -4544 -19520 R90
WINDOW 0 0 32 VBottom 2
WINDOW 3 207 73 VTop 2
SYMATTR InstName D6
SYMATTR Type diode
SYMBOL schottky -4624 -19504 R0
WINDOW 0 43 30 Left 2
WINDOW 3 -61 205 Left 2
SYMATTR InstName D8
SYMATTR Type diode
SYMBOL schottky -4624 -19392 R0
WINDOW 3 -61 93 Left 2
SYMATTR InstName D9
SYMATTR Type diode
SYMBOL schottky -4592 -19984 R270
WINDOW 0 32 32 VTop 2
WINDOW 3 283 -18 VBottom 2
SYMATTR InstName D11
SYMATTR Type diode
SYMBOL cap -4992 -19328 R180
WINDOW 0 32 52 Left 2
WINDOW 3 24 12 Left 2
SYMATTR InstName C6
SYMATTR Value 10n
SYMBOL diode -4912 -19696 R0
SYMATTR InstName D10
SYMBOL schottky -5408 -20032 R90
WINDOW 3 32 32 VTop 2
SYMATTR InstName D12
SYMATTR Value MBRS130L
SYMATTR Type diode
TEXT -5624 -19744 Left 2 !.tran 0 0.55mS 100u 100u uic
TEXT -5584 -20200 Left 2 !.include irgp4063dpbf.spi
TEXT -5584 -20168 Left 2 !.include IRG4PH50UD.spi
Hi Simon,
Just in case you are still watching,I downloaded the .asc file,but the symbol for IGBT is missing.LTS gives an error msg, saying symbol not found.Anyway to handle this?
Ooops sorry,I got it after reading your post better.
hi i need an igbt model to create an shunt active power filter, actually i downloaded the igbt.txt in this page.. and when i try to create the symbol it is showing me this error
'trouble in creating directory "C:\programfiles\LTC\LTspiceIV\lib\sym\Auto generated'
usually this is a permission problem
can any one help me on this please
Hi
Sorry for this late reply, but...
LTSpice does not recommend custom files of any type be placed in the program folder hierarchy.
Custom subckt files should be placed in the schematic folder.
.model statements can be placed directly on the schematic.
If a .model statement is contained in a file, it must be wrapped with .subckt and .ends statement along with a device definition
Directives .lib or .inc should be used to inform LTspice of the custom subckt file location.
This model statement is incorrect:
MODEL IXGT32N170A NIGBT <-------there is no "NIGBT" device, should be "NMOS"
+ TAU=63.552E-9
+ KP=14.397
+ AREA=16.000E-6
+ AGD=6.4000E-6
+ WB=117.00E-6
+ VT=5.3804
+ MUN=1.0000E6
+ MUP=150
+ BVF=9.9990
+ KF=.5005
+ CGS=38.737E-9
+ COXD=88.530E-9
+ VTD=-5
eT:)
6th Sept 2016: LTspice XVII has an NIGBT and an PIGBT model. Download this version of LTspice from linear.com
Select the new component icon (the AND gate symbol in the toolbar), then go to the MISC directory. They are in there
really no one to help?
Seriously dude? Seems to me Simon has been helping you quite a bit. Stuff takes time... Geezo
Not sure what the hassle. I got this working within about 30 minutes using Simon's instructions and making sure the references were in the right places
Capt Kurt
It is much easier now LTspiceXVII has an IGBT model. I always recommend downloading external spice files into the directory you are working in and NOT the LTspice directories. Then if you reinstall LTspice for whatever reason, the reinstallation process does not wipe out your model.
