andy257 said:Where does the modulation aspect of these pulse width modulators come from? I know they require an oscillator but i dont understand how modulation comes into it. Doesnt it require a second frequency to modulate?
andy257 said:I was looking at audioguru's project here https://www.electronics-lab.com/projects/games/004/index.html
What i didnt understand was where does the modulation come into this.
I studied modulation in my communications class and from what i learnt there must be a carrier and an information source (message signal) for modulation to occur. I know there is an oscillator in the circuit but where is the modulation taking place.
If there were two oscillators that would make sense but there appears only to be one.
andy
Styx said:andy257 said:I was looking at audioguru's project here https://www.electronics-lab.com/projects/games/004/index.html
andy
did you even read my reply?
JimB said:Andy
I think your confusion comes from the use of the word "modulation" in two different contexts.
You are thinking of modulation in terms of modulating the carrier of a radio transmitter, where an oscillator provides the carrier, and the voice the modulation.
In this context, Audioguru is changing (modulating) the width of a pulse in order to vary the brightness of his LEDs.
He is modulating at a very low frequency, ie whenever he moves the R7 "brightness" control.
When he has stopped rotating the control, the pulse width (and brightness) is fixed until he turns it again.
I hope this clears your confusion.
andy257 said:Bugger i thought i understood it for a moment there. So it has nothing to do with modulation after all?
where does the triangular waveform come from? if its the oscillator then where does the sine wave come from? is it from the rising and falling voltage/current?
andy257 said:It would be alot better to leave the name modulation out of it and call it a pulse width something........., then i wouldnt have been confussed.
leave the word modulation for things regarding communication etc![]()
Nigel Goodwin said:andy257 said:It would be alot better to leave the name modulation out of it and call it a pulse width something........., then i wouldnt have been confussed.
The confusion is all your own I'm afraid 8)
Communication is only one small part of things that are modulated, the term modulation is perfectly correct for PWM (and the many other non-communication uses for modulation).
In any case, PWM is a perfectly valid communication technique, and is often used.
