Q
Quan
Guest
I did have that!
I fixed the code and it WORKS!
I just gotta create a shorter directory and IT IS ALIVE!!!
;*** WDT reset toggles RB0
list p=16F628A
include <p16F628A.inc>
__CONFIG 0x3F34
org 0
bsf STATUS, RP0
movlw b'00001110'
movwf OPTION_REG
movlw b'11111110'
movwf TRISB
bcf STATUS, RP0
xorwf PORTB, f
sleep
end
Connecting to MPLAB ICD 2
ICD0019: Communications: Failed to open port: (Windows::GetLastError() = 0x2, 'The system cannot find the file specified.
ICD0021: Unable to connect with MPLAB ICD 2
MPLAB ICD 2 Ready
ICDWarn0034: Please ensure that your system's serial FIFO buffers are disabled.
...Connected
Setting Vdd source to MPLAB ICD 2
ICDWarn0020: Invalid target device id (expected=0x83, read=0x0)
...Reading ICD Product ID
Running ICD Self Test
...Passed
MPLAB ICD 2 Ready
...Connected
...Passed
MPLAB ICD 2 Ready
Programming Target...
ICDWarn0052: MPLAB ICD 2 cannot validate a target device. Please make sure that the target device is connected and properly powered. Select "OK" to continue, or "CANCEL" to abort the operation
...Validating configuration fields
...Erasing Part
...Programming Program Memory (0x0 - 0x7)
Verifying...
...Program Memory
ICD0161: Verify failed (MemType = Program, Address = 0x0, Expected Val = 0x1683, Val Read = 0x0)
ICD0275: Programming failed.
MPLAB ICD 2 Ready
...Connected
...Passed
MPLAB ICD 2 Ready
ICDWarn0054: MPLAB IDE has lost communications with the MPLAB ICD 2. Would you like to attempt to reconnect?
...Connected
...Passed
ICD0082: Failed MPLAB ICD 2 operation
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
...Program Memory
MPLAB ICD 2 Ready
Reading...
ICDWarn0038: When using auto-calculate write range, reads cover the entire memory range. Do you wish to continue?
...EEPROM
...Program Memory (0x0 - 0x7FF)
.. Config Memory
...User ID Memory
...Read Succeeded
MPLAB ICD 2 Ready
...Erasing Part
...Programming EEPROM Memory
...Programming Program Memory (0x0 - 0x7FF)
...Programming User IDs
Verifying...
...Program Memory
...EEPROM
...User ID Memory
...Verify Succeeded
Programming Configuration Bits
.. Config Memory
Verifying configuration memory...
...Verify Succeeded
...Programming succeeded
04-Oct-2007, 17:18:01
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
...Program Memory
...EEPROM
...User ID Memory
...Verify Succeeded
.. Config Memory
...Verify Succeeded
04-Oct-2007, 17:25:49
MPLAB ICD 2 Ready
Reading...
...EEPROM
.. Config Memory
...User ID Memory
...Read Succeeded
MPLAB ICD 2 Ready
Reading...
...EEPROM
...Read Succeeded
MPLAB ICD 2 Ready
Blank Checking...
...Program Memory
ICD0161: Verify failed (MemType = Program, Address = 0x0, Expected Val = 0x3FFF, Val Read = 0x0)
...Device not blank
MPLAB ICD 2 Ready
Erasing Target Device...
...Erase Succeeded
MPLAB ICD 2 Ready
Verifying...
...Program Memory
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
...Program Memory
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
...Program Memory
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
...Program Memory
MPLAB ICD 2 Ready
...Erasing Part
Verifying...
ICD0200: Operation Aborted (Warning 51).
MPLAB ICD 2 Ready
This msg is telling you that the ICD2 is not able to read the target chips device ID. It is a show stopper.ICDWarn0020: Invalid target device id (expected=0x83, read=0x0)
Sorry about blowing up, it appeared that the problem was human error![]()
This a good chance to get you feet wet with the inchworm.Krumlink said:That sound's like a good idea actually. I have the Resistors DIP sockets, but not the caps, ST232 16F877 (I have the A version, but I dont know how to program it) or the other misc sockets. I am restocking my stuff soon here.
You can not program it with the code from Bill's poster. The 16F877 is close but you still need to figure out a new CONFIG value and change the include statement.Can I use a 16F887?
