question about PIC 16C711
escin
erm.. i want to build a peak charger that using PIC 16C711 4Mhz.Do i need to program it on my own or it is already programed by the manufacture.u may refer to this attachment.it is in PDF format.
  • 16c711_peak_detect_charger.pdf
The PIC16C711 is an OTP (One Time programmable) PIC micro-controller, they normally come from MicroChip totally blank - although if you care to order sufficiently large numbers you can order them pre-programmed with your own code.
You would need to either buy a pre-programmed one from the designer of the project, or program your own - assuming the designer provides the required code!. If the designer doesn't provide the code, your only option is to buy a pre-programmed one from him.
