While trying to build a interface for a gps board to pc serial port, being pointed in the direction of using the maxim max710 5v dc-dc converter for the power control I've come to a stop.
How would I find the value of a capacitor listed on a diagram as C1,C2,C4? I have read the data sheet over and over maybe I can't see the wood for the trees :shock:
The 710 has a shutdown and standby mode if the related pin receives a ground but what will happen if the 710 is supplying the power to the chip that gives the command to shutdown?
Also which would suit my interface better the typical operating circuit or the low-noise?
Hope the questions make sence as its pretty hard asking the right questions when your not sure what your doing
the data sheet for the items Im using.
https://www.electro-tech-online.com/custompdfs/2003/04/MAX710-MAX711.pdf
https://www.electro-tech-online.com/custompdfs/2003/04/MAX221.pdf
paul
paul
