Im going to make this fast so I don't waste to much time. Basically lets say I have 2 devices and a 12 volt battery. One device is a 12 volt Motor, while the other device is a 3 volt LED. Is it possible to put these 2 devices in series and some way make it so that the lightbulb will not burn out? Im not to sure which way the electrons flow from, Positive to Negative? So would adding a resistor between the motor's negative and led's positive lead work? Im not to sure...
Battery Positive ----> Motor Positive
Motor Positive ----> Resistor
Resistor ----> To Led
Led ----> Battery Negative?
Will this work?
Thank you for your time
Basically I am making this circuit so that if the motor dies/fails or something is wrong with the connection the LED will indacate this.
Will this work?
