bananasiong said:Is there an extra wire for the antenna in the earphone? Or the left and right side line act as antenna?
I would like to see that, however there is the issue of millions of radios been rendered obsolete.TheVictim said:Since analog television is biting the dust in 2009, I wonder when we are going to see the AM broadcast band as we know it going bye-bye. I can see digitally coded SSB taking it over.
Wow, this is so interesting, I have never heard about this. So the earphone wire has to be long enough in order to receive the signal well? How if the wire is bent? I thought the single pole antenna has to be straight and the length of at least a quarter of the wavelength?audioguru said:No additional wire is needed when the headphones wires are used as an antenna:
Choke coils in series with the headphones wires pass the audio signal but block the RF signal from being shorted by the audio amp's output.
Then the RF signal is coupled to the radio through a low value capacitor that has no effect on the audio signal.
audioguru said:If the antenna wire is a quarter-wavelength long and is in the same plane as the transmitting antenna then the reception is best.
