HI;
I was an electronics teck in the USArmy when everything had these orange glowing glass tubes that got very hot. So I know basics.
A man i met at the Local Hobby Shop is building a RC model P38 Fighter plane with a 9 1/2' foot wing span. He was a fighter pilot in WWII and flew, you guessed it, P38s.
The P38 had 4 machine guns and one cannon, 20mm I believe, all located in the center pod with the pilot. My Pilot friend wants to have bright rapidly flashing white LEDs or orange or yellow, in each barrel to simulate firing. He will have a sound system too.
The references I have found on the web are mostly low power red and don't flash fast, more like 2 a sec. which might be OK for the canon but the machine guns are much faster. Or so old that the sources they quote are gone.
There will be 12v or more available on the plane, it is an electric powered plane, or a few subC cells won't bother the overall weight of the plane.
What I need is a simple flasher i can repeat 4 or five times or one that flashes 2 LEDs alternately ( would build two) I don't want any of the light to flash at the same time as another.
Sounds easy, any help will be greatly appreciated;
That Fviking.
That Fviking.
