Hello all, I have a model airplane that I need to add controls too. I just want a simple on/off circuit that will take a receiver command and use that to activate another circuit, such as to use the switch on the airplane remote to turn on a flashlight, etc... I don't want to do this mechanically because don't want to worry about the space/cost/power requirements of a servo.
The receiver output is 3 posts, red,black, yellow. Red and black are used to drive a servo motor and are constant at 5V. Yellow varies based on the switch position, Anywhere from 0 to .3V. I have bought and tried a transistor that is activated by the .3V and then activates the other circuit powered by say a 9V battery. My problem is that the voltage from the receiver is too low and doesn't activate the transistor. I need some kind of device that will activate the transistor/2nd circuit without killing the receiver. It should be simple, but I don't know exactly what circuit to make.
I dont know what kind of current comes out of the reciever, I forgot to measure it. I think some kind of transistor loops, like a Darlington pair or something like it to step up the voltages enough.
