Grossel
Hi folks.
Have an 10 year old DVD rewritable drive (DH-16ABS12B) where the rubber band - that eject/retract the tray - is splitted. The rubber band has a cross section of 1x1mm (square).
I hope to be able to repair it by joining the ends together, and here is the plan:
I expect the following problems:
My questions on this:
- Carefully make a split alongside that goes no further than around half way (~0,5mm). Alongside split may measure about about 10-20mm from the cut point, in both directions.
- Put a string of some material into the split. This must be a durable material.
- Put some glue in the split.
- press the two sides of the rubber band that is on sides of the split while the glue get dry.
- It will be very difficult to make the split go along the center of one side of the rubber band, while it don't get too deep (if the band split completely it's probably defect ?)
- Find a string that is suitable (unsure if a regular spool of thread for sewing is good enough)
- Find a suitable type of glue that can hold up against movement
- Suggestion on an alternative plan (not buying) that involves mostly house hold products.
- Any ideas on how to best overcome the problems above - especially the first one?
