Anonymous_person
Hello Again,
So correct me if I'm wrong, I would need to remove the termination resistor the input of one of the Video devices (either the PC capture card or the Denon 1910).
As I wouldn't want to touch the Denon 1910, that leaves the capture card. I'm guessing find a 75 ohm resistor that is located as close to the composite input as possible (if it uses the 3 number smd code, it should be labeled as 750 correct?) and this should be the one, correct?
Unless I'm mistaken daisy-chaining the connections like this relies on the capture card in this instance having a high impedance input after the 75 ohm resistor correct?
I've yet to get the capture card, but will soon. If there is a problem locating the right resistor I might need some help...
If this is correct, sorry I didn't get it sooner, I didn't pick up on the implication of modifying one of the inputs...
Owen.
Owen.
