Hello,
I have a home made circuit (arduino) that I want to use in my car, powered from a 12v source. I already have a lm7805 voltage regulator in my circuit, and it works when hooked up to the 12v car power, however even with a heat shield on it, it still gets too hot to touch after a few minutes. The circuit carries very little load, it basically just powers a 2 line VFD display.
I was think to reduce the 12v down to something manageable like about 9/8 volts before feeding that to my circuit, using a resistor based voltage divider.
Does this seem reasonable to reduce the 12v power down before feeding to my circuit by using a resistor based divider? I already have my circuit all soldered together and the LM7805 is soldered in place as well, so I'm trying to avoid tearing it apart.
Here's wiki pic of a divider (I know you all know it, but for reference sake) ...
https://upload.wikimedia.org/wikipedia/commons/d/db/Resistive_divider.png
This is silly, but I'm not sure how to hook this up. The Vin would be my car's 12v. The Vout would be my circuits power + wire. And my circuits negative - wire would go ...? Do I just connect my circuit negative together with the dividers ground, and connect both those to the ground wire on my car?
Thanks for any feedback.
Cheers.
Cheers.
