relay advice required
oOo Les oOo
I looking for some help, I have a device that when conditions are met it turns on a small motor to provide vibration feedback. The current feedback is very weak and I would like to add a much larger motor with speed controller to give adjustable feedback.
Would it be safe to add a relay replacing the motor that would turn on the replacement motor. I have measured the voltage across the motor when activated at 3.8 volts dc.
As-is
PCB - Motor
New
PCB - Relay - 12v psu - Speed controller - Motor
If this looks ok can someone recommend a relay
Depends on a few things and for starters how much current the new motor will draw.
Ron
So the load can be from 1.4 to 2.85 Amps. For what you want to do, and in keeping it small, I would think about looking towards a small automotive relay that can be easily had in any automotive parts store at a reasonable price.
Ron
Thanks, I was worried about potential damage to the other electronics on the PCB due to replacing the motor with a relay
Just make sure you place a diode in parallel with the relay coil and observe polarity with the diode. Cathode of diode to + side and anode to the - side. You don't want an inductive kick from the coil when it is de energized hitting your components.
Ron
