Hi. New to the forum here.
what Im doing is simple. Im hooking a small 12vdc .3 amp flow pump to a relay controlled by a switch. The relay is a yong lin YL-314-c-12VDC single pole double throw and the coil draws .13 amps. I tested the relays hooked up to the pump with my RSR electronics inc 3040 power supply and the relay will not engage the contact and it just chatters when I throw the switch to the coil. Now when I physically press the contact down it engages and stops chattering.
The rating for the power supply is 1amp at 12 volts. At maximum the relay and pump are only drawing .43 amps. What I want to know is should I put a damper capacitor in there, Where should I put it and what kind do I need. Also consider that this relay and pump will be going into my truck and will be supplied by a much heavier capacity circuit (which I haven't tested yet).
Is this a problem with the motor suddenly drawing alot of current and draining power for the relay coil and causing it to chatter. Or am I missing something.
I haven't dealt with anything electronics related in over 10 years. I have experience but I a little rusty.
