bananasiong
I'm using a relay to switch the life terminal of the main socket digitally. Can I just use a thick multi core wire and solder to the NO or Common terminal of the relay? Do I need to use a relay socket like this:
**broken link removed**?
The relay is rated:
coil: 12 Vdc
contact: 5A, 240 Vac
I'm not going to use the socket if possible because of its size.
The relay is rated:
coil: 12 Vdc
