Peter_wadley
Olla!
I haven't gotten around to working with relays in my projects yet and would like to do so..
I understand how they work. However, there seems to be so many different variations available.. im at a loss for choosing the right one.
Basically, Id like to use a PIC to control 120V AC appliances.
None of which exceed a current of 10A.
So I guess that would mean I need a NO (Normally open) .. correct?
What other specifications would it need to be?
Im pretty sure I read that low voltage DC can switch higher voltage AC in the WIKI relay page.. which is pretty much the point of relays in the first place![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Would I need to use a transistor to increase the output current of the PIC when switching the relay??
Also a diode should be put in parallel with the relay correct?
Best regards,
Best regards,
