So what are you defining as Very High pressure?
I built my pressure washer with a 3030 comet pump and a 7.5 hp 3450 RPM electric motor. The gauge reads 2900 psi and the flow rate is 3 gpm.
I commonly hook up to my boiler and use 190 degree F water for bad grease removal and it does a super job of removing ice from my vehicles in the winter!
I have been washing my vehicles and equipment for years now with it and the only paint trouble I have is on stuff with bad quality paint jobs. Typically stuff that was repainted with spray cans or stuff that has been repainted where the painter just sprayed right over unprepared surfaces.
If the paint job is crappy or the quality of work done while painting is bad then its only a matter of time before the paint is going to peel anyway.
And dont assume that just because its a factory paint job its done right! I have a few friends that are auto body specialists and they say that some the factory paint jobs (Ford, Chevy, Chrysler, John Deere
) at times are of lower quality than if a person had done it with a spray can!
But I would try pressure washing the asphalt myself. I doubt it would take all that much pressure to work the clay out. I often use my pressure washer to remove grease and oil stains from concrete and get great results.
