Repairing Automotive Check Control Box
AaronsCars
Hi guys, I’m working on repairing some electrical issues on my old car.
The gauges are a bit wonky, some don’t work and on the special occasion that they do they bounce up and down.
I am currently going through the wiring of the car, but one issue I (may) have found is the check control box which controls the gauges.
I took it apart last night, the circuit board looks fine, no broken lines or melted solder joints. But I did find this green diode(maybe?) that looked like it had gotten hot.
What is this green thing and is it something replaceable? It has 5%T7 written on it.
I am not an electronics wizard, but these little projects with my car are what I’m learning on.
A new check control module is $350, and before I drop that kind of cash I would like to prove that I need it!
Thanks in advance
Aaron
Looks like a wirewound resistor, they do tend to get quite warm in normal use, hence the darkening of the circuit board due to heat.
Not very helpful, there is probably some more information on the underside of the resistor, next to the circuit board.
Okay I shined a bright light on it and under it I could see 68 ohms inscribed on it
Tested it with a meter, and it’s got 68ohms
So I think you’re right, it’s just gotten hot.
I cleaned all the contacts for the plugs and placed it back on the car. Will test soon after I get the fuse box and wiring figured out
