Repairing rotary encoder for Creative T6 volume control pod
tristanlee85
I am attempting to repair a volume control pod for my Creative ZiiSound T6 system. The symptom I was experiencing was when adjusting the volume knob in either direction, the volume would either be unchanged or continue to increase in uncontrolled increments.
This knob can spin infinitely in either direction by rotating the upper half.
Because I could not see anything on the board or component itself that would identify it, I opted to take it apart to see how it functioned and see if I could match a replacement to it. Researching various encoders, I wasn't able to find anything that I comfortably thought would be a good replacement.
Does this pattern look common or is it likely something proprietary to the device? Any feedback would be great, thanks!
Presumably it's just a rotary encoder?, assuming you haven't broken anything?, just clean it and put it back together - your issue is a VERY, VERY common problem with rotary encoders.
It 'might' be a standard rotary encoder, but you don't actually give any pictures of it, just the disassembled parts.
Get a "Pink Pearl" pencil eraser and clean the copper contacts and 3 rotating contacts to be smooth and mirror like. Then reassemble dust tight. The rotor switch has 12 cycles per rev., with contact closures. It is a problematic design with corrosion and plastic smear.
A non solvent grease extremely thin so that the contact force reaches the conductor surface may help. Use a DMM continuity buzzer to test before resoldering and beware of excess heat. 3s max per joint.
It does look like a common Alps or Bourns encoder, readily available from many sources.
If you re-assemble the original, wipe the track with thin oil or a light grease (not silicone!), that will reduce wear and prevent tarnish.
