Yes, you are correct. Current will only flow one way through a diode.ThrowingChicken said:I know what an LED is, and I had a vague understanding of what a diode was; like I kept asking, is it like a check valve?
Your problem with modifying a typical chaser circuit using an IC like the 4017 will be the limited current capability of the 4017s outputs. The 4017 can only drive one (Maybe 2 if you push it a little out of spec) LED at a time. Your diode idea would require the last output to have to drive all 10 LEDs at once resulting in a very dim display because the 4017 will not be able to source that much current.I have no problems putting together a chaser kit, it's the modification for my needs I don't know much about
