It is summer and my air conditioner isn't perfect. It is frequently 30 degrees C. Also, the LED is going to be mounted in something that will block cooling air flow to it.Marks256 said:Yes, but isn't 25°C room tempurature?
Not if its ambient air is more than 25 degrees C.So then it should run at 100mA?
I would probably use 80mA max because the performance isn't much less but the reliability will be greatly improved.What would you suggest running it at? And why would you run it at that?
