thanks for ur responcePapabravo said:What kind of answer do you expect when you provide so little information? Do you think a serious answer is even possible?
What is the input voltage and power?
What is the output voltage and power?
Are these rquirements within the capability of the chip?
Have you searched the manufactureres website for application notes?
Do you think the design will require an external switch?
Will the inductor be off the shelf or custom?
Is the use of an alternative converter possible?
zainwd65 said:Better u use SG3525 as PWM controller
if u looak to the thread titile "Reuest UC3843 Application circuit In DC DC converter "Papabravo said:You might want to try and learn to crawl and walk before you try to run a marathon.
One of the other posters suggested a SG3525. I thought you might be interested in solving the problem of building a DC-DC converter. It seems as if you lack the capability to read a manufacturer's data sheet, or application note, and come up with your own design. If that is the case you might want to start with a CAD package and a design that you can experiment with without actually building one. If you're going to be rude and ungrateful then you're on your own.wael_sal said:if u looak to the thread titile "Reuest UC3843 Application circuit In DC DC converter "
I need help on UC384X not to use other controller !!
thanks at all
It might be that the part is unsuitable for your requirements. In any case you're on your own.wael_sal said:Refering to the first post "I need to use it ***offline *** " ie the UC3843
All data sheets and application notes I had seen, As mentioned before all consintrating on flyback !!!!!
