It is audio that you do not hear.MrDEB said:the outputs from the LM837 feed into the 3916. This is not audio??
Yes.I get from your answer that I should stick with the poly caps?
The positive supply needs a capacitor to ground and the negative supply needs a separate capacitor to ground.decoupling caps on power pins?I should include but his is a duel power supply.
No. The two supply capacitors will be in series and provide good all around decoupling.decoupling between the V+ and V-?
No. Pots do not oscillate if they do not have supply bypass capacitors. ICs do.Another question arose = the 10K duel pots are on another board using 2- 10 pin ribbon cables. the ground is on a 4 pin cable. should I use any decoupling caps?
