FirefighterBlu3
General approach is a tiny module that is powered by a solar cell to recharge a capacitor which drives ~6 high brightness LEDs for about 5 minutes when it receives an RF signal. The idea is that these LEDs will light up and start rapidly blinking when a RF trigger enters a given radius. I'd like to build the circuit in less than 2cm by 2cm square, and about 7-10cm tall.
What I need to find is an RF module/chip that controls a true/false logic indicating to a tiny microcontroller when to power up and run a simple program. I think I can handle the rest of the circuitry fine but I need to find a chip that I can set up to handle the RF listening. Ideally I'd like the range to be about 250-500ft and this should be considered an outdoor device.
The end result is a tiny box I can affix to a poly/fiberglass rod which will be located on/near a fire hydrant. It's purpose is to indicate where a fire hydrant is positioned during heavy snowfall.
Suggestions welcomed
I have no RF signal constraints other than the FCC, no special design requirements except for very low sleep current. There may even be an analog method but I am _horrible_ at analog theory =]
