crowinu said:hi guys,
i got to know that in a tranciever , the transmitter and receiver can't work simultanously , is it true or not ?
thanks
crowinu
Nigel Goodwin said:crowinu said:hi guys,
thanks
crowinu
It depends exactly what it is, but generally it's true, this is known as 'half-duplex', both transmitting and receiving at the same time is MUCH more difficult, usually requiring widely spaced frequencies, and is called 'full-duplex'.
crowinu said:Nigel Goodwin said:crowinu said:hi guys,
thanks
crowinu
what can i do to eliminate this problem ? any ready made full duplex tranceiver modules ?
Nigel Goodwin said:crowinu said:Nigel Goodwin said:crowinu said:hi guys,
thanks
crowinu
What EXACTLY are you wanting to do?.
crowinu said:what type of protocol you suggest ? i was going to use the serial rs-232 protocoo!
@philba : i never worked with tranceivers, is a modem more easeier to use and if yes y ? links you gave me are chips whihc i dont like to use since my main project is on controlling of the robot and note wirless connection ?!
Nigel Goodwin said:crowinu said:what type of protocol you suggest ? i was going to use the serial rs-232 protocoo!
Either use modules with in-built coding, or add Manchester coding before and after the modules - check my tutorials for details.
