I have built up a two transistor wideband amp. to boost a composite video signal shared by three outputs from a satellite receiver scart output which works fine. i.e. there is no obvious degradation. The alternative would have been to remove some/all of the 75 ohm trminating resistors in the shared receivers. The signal is AC coupled in and out. I have a 42" plasma t.v. with the primary input (again satellite) via a scart RGB input. The problem is that the maximum contrast is almost, but not quite enough which is irritating. I would like to use three of these amps for R G and B, but am not sure if the signal can still be AC coupled without losing proper black level. Any ideas?? Thanks for help
