How does he find time to do the Inchworm etc. PCB's?, he must surely spend all his time creating his great drawings!.
bloody-orc said:to make a diode, resistor, or similar, it takes 1 minute.. for IC i assume 5... component placement 15 minutes... whole PCB maybe 1h![]()
So am I going to get any cred for that?So looks like the SN754410 is the new Mongoose H-Bridge.
Hank Fletcher said:So am I going to get any cred for that?
The info in the datasheet isn't 100% clear on this. At the top, it lists 1A per driver, which would mean 2A per chip, but it's not clear whether or not this is the peak or continuous rating. It's also not clear what kind of failure to expect when the specs are exceeded (it just says, "Look, don't expect it to run properly if you force the specs," standard component rules).It's my understanding 1A total, they can be stacked and I will have as much copper on the PCB under the chip as I can put there.
