RTC DS1307 Backup battery
Dear Rogers,
Thanks for the reply
I identified a problem with my I2CRead() subroutine, but it is working. please see below I2C Read() subroutine
void I2Cread(){
		for(i=0;i<8;i++){
        I2CStart();
		I2CSend(0xD0);							/* Send slave address with write */ /* Send address for dummy write operation *//* this address is actually where we are going to read from */
        I2CSend(0x00);							/* Send a repeated start, after a dummy write to start reading */
        I2CRestart();
        I2CSend(0xD1);							/* send slave address with read bit set */
      			I2CData[i] = I2CRead();			/* read a byte */								/* ACK if its not the last byte to read */
		 	I2CStop();							/* Send stop */
In the above code the FOR loop is placing in wrong place, but it is working
and see below codes. I put for loop in correct location,but it does not working
void I2Cread(){
        I2CStart();
        I2CRestart();
				for(i=0;i<8;i++) {
Please advice
Thanks in advance
I did that for you a few posts back.... The read function MUST reply to the DS1307 If you send an ACK the data will keep comming... You send a NACK to stop reading SEE POST #7
void I2Cread()
        I2CStart();
        I2CRestart();
		for(i=0;i<7;i++)
 				I2CAck();
		I2CNak();
This works
Dear Rogers,
My next step is to add three switch to the cct for adjust the time. Therefore I added three micro switch to PORTB pin 4,5,6 and ground each via 47Ω resister. Could you please advice nest steps
Thanks in advance
47Ω resister
5 / 47 = 100mA No no no... Micro's can't source that.... Try 470Ω +.. It will survive better.
The next step is to write a key read function that will read, debounce and acknowledge a key press...
Hi guys I have the same problem.... When Mains power is removed ..... & given back again , the time gets resetted... So please help me............
