I've done some work on it but I have a one specific question
Is my main function doing the right thing to send device address with write mode ?
C:
#include <reg51.h>
#define I2C_DELAY 50
#define TOGGLE_LED 20000
#define device_addrW 0xD0 //device address with write 1101 0000
#define device_addrR 0xD1 //device address with Read 1101 0001
#define ACK_BIT 0
sbit SDA_BUS = P2^0; //Define the Pin for the I2c and lec
sbit SCL_BUS = P2^1;
sbit Led = P3^0;
void InitI2c(void);
void StartI2c(void);
void RepeatedStartI2c(void);
void StopI2c(void);
void SendAckBit(void);
void SendNackBit(void);
void delay(unsigned int);
bit write_i2c(unsigned char);
unsigned char read_i2c(void);
void write_byte_to_DS1337(unsigned int,unsigned char);
unsigned char read_byte_from_DS1337(unsigned int);
/**This function provide the delay which is used in clock generation.
void delay(unsigned int d)
unsigned int i;
for(i=0; i<d; i++);
/**This function use to make the data line and clock line idle to put the both line high
void InitI2c(void)
SDA_BUS =1;
SCL_BUS =1;
/**This function performs the start operation to initiate the communication.
void StartI2c(void)
SDA_BUS = 1;
SCL_BUS = 1;
delay(I2C_DELAY);
SDA_BUS = 0;
delay(I2C_DELAY);
/**When master does not want to relaese the control from the bus then it assert the repeated
start condition on the i2c bus.
void RepeatedStartI2c()
SCL_BUS = 0;
delay(I2C_DELAY/2);
SDA_BUS = 1;
delay(I2C_DELAY/2);
SCL_BUS = 1;
delay(I2C_DELAY/2);
SDA_BUS = 0;
delay(I2C_DELAY);
/**When master want to stop the communication then it will assert the stop condition to the i2c bus.
void StopI2c(void)
SCL_BUS = 0;
delay(I2C_DELAY/2);
SDA_BUS = 0;
delay(I2C_DELAY/2);
SCL_BUS = 1;
delay(I2C_DELAY/2);
SDA_BUS = 1;
delay(I2C_DELAY);
/**This function use to send the acknoledgement(ACK) bit the i2c bus.
void SendAckBit()
SCL_BUS = 0;
delay(I2C_DELAY/2);
SDA_BUS = 0;
delay(I2C_DELAY/2);
SCL_BUS = 1;
delay(I2C_DELAY);
/**This function use to send the Non-acknoledgement(NACK) bit the i2c bus.
SCL_BUS = 0;
delay(I2C_DELAY/2);
SDA_BUS = 1;
delay(I2C_DELAY/2);
SCL_BUS = 1;
delay(I2C_DELAY);
/**This function use to send signle byte to the I2C Data Bus*/
bit write_i2c(unsigned char byte)
unsigned char i;
for(i=0; i<8; i++)
SCL_BUS = 0;
delay(I2C_DELAY);
if((byte<<i)&0x80)
SDA_BUS = 1;
else
SDA_BUS = 0;
delay(I2C_DELAY/2);
SCL_BUS = 1;
delay(I2C_DELAY);
//ack from slave //
SCL_BUS = 0;
SDA_BUS = 0;
delay(I2C_DELAY/2);
SCL_BUS = 1;
delay(I2C_DELAY);
return SDA_BUS;
/**This function use to read the data from the I2C data bus*/
unsigned char i,d, rxdata=0;
for(i=0; i<8; i++)
SCL_BUS = 0;
SDA_BUS = 1;
delay(I2C_DELAY);
SCL_BUS = 1;
delay(I2C_DELAY/2);
d=SDA_BUS;
rxdata=rxdata|(d<<7-i);
delay(I2C_DELAY);
return rxdata;
/**This function use to single byte the DS1337 at desire address
*///Write Data to DS1337
void write_byte_to_DS1337(unsigned int addr,unsigned char byte)
StartI2c();
while(write_i2c(device_addr|0)==1)
StartI2c();
write_i2c(addr>>8);
write_i2c((unsigned char)addr);
write_i2c(byte);
StopI2c();
\brief of read_byte_from_DS1337 function.
This function use to read the data byte from DS1337 at the desire the address
unsigned char read_byte_from_DS1337(unsigned int addr)
unsigned char rxdata =0;
StartI2c();
StartI2c();
write_i2c(addr>>8);
RepeatedStartI2c();
write_i2c(device_addr|1);
rxdata=read_i2c();
SendNackBit();
StopI2c() ;
return rxdata;
// Main function
void main(void)
unsigned char rxbyte=0;
unsigned char cSendByte = 0x00;
Led = 0;
SDA_BUS = 0;
SCL_BUS = 0;
InitI2c();
write_byte_to_DS1337(0xD0, cSendByte);
