Shake_ECET209
Hi Guys, I am making a RTC that displays military time at the push of a button. I am using the code from the RTC lab we did and adding the LCD screen, but the code uses the RS232, and instead i want to use the push buttons on the board to set the time/hr/min and then display that time in military time.
Can anyone help me remove the use of the RS232 in the code we have not gone over it yet and I am really not similar with it.
Also Do I only need to change the <16F88.h> header file in order to make it work for the 16f88??
Thanks guys any help is appreciated
#if defined(__PCM__)
#include <16F877A.h>
#fuses HS,NOWDT,NOLVP
#use delay(clock=20000000)
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
#elif defined(__PCH__)
#include <18F4520.h>
#endif
#define _USE_LCD_
#define CLOCKS_PER_SECOND 1000
#include <time.h>
#include <rtctimer.c>
#include <stdlib.h>
#include <input.c>
#if defined(_USE_LCD_)
#include <lcd.c>
#endif
void InitTime(void)
struct_tm t;
//tm_year is years since 1900.
printf("\r\nYear (0-99): ");
t.tm_year = (int16)get_int() + (int16)100;
printf("\r\nMonth (1-12): ");
t.tm_mon = get_int() - 1;
printf("\r\nDay (1-31): ");
t.tm_mday = get_int() - 1;
printf("\r\nHour (0-23): ");
t.tm_hour = get_int();
printf("\r\nMinute (0-59): ");
t.tm_min = get_int();
SetTime(&t);
printf("\r\n\n");
void main(void)
char tString[32];
int i = 0;
time_t tTime = 0;
lcd_init();
#endif
printf("\r\n\nex_rtctimer\r\n\n");
InitTime();
#if getenv("CLOCK")==4000000)
setup_timer_2(T2_DIV_BY_1,250,4);
#elif getenv("CLOCK")==20000000)
setup_timer_2(T2_DIV_BY_4,250,5);
#else
#error Configure TIMER2 so it interrupts at a rate defined by CLOCKS_PER_SECOND
#endif
enable_interrupts(INT_TIMER2);
enable_interrupts(GLOBAL);
while(1)
tTime = time(NULL);
ctime(&tTime, tString);
printf("It is currently: %s\n\r", tString);
lcd_gotoxy(1,1);
i = 3;
while(tString[i] != '\0')
lcd_putc(tString[i]);
i++;
#endif
delay_ms(1000);
