Running Dos programs on Wnidows XP can it be done?.
Viking
I have some old Dos ham radio programs that I would like to run on a
pentium with WindowsXP, i have tried several times but no luck,
wondering if there is a way to do that ?
Viking.
Dos on winXP
Unfortunately you may be out of luck... WinXP runs a DOS emulation which you can try running your apps by performing the following:
Click Start, then click run
Type cmd and click ok
Your DOS Prompt will come up
Locate the software and try to execute it.
Otherwise, I recommend finding a temporary PC to run Win98SE to work with your DOS applications.
Good luck!
I had a problem trying to use the DOS emulator in Windows 98. It ran some programs but could not cope with TSRs.
I got round the problem by using 'Adaptec' to make a bootable DOS 6.2 CD. It works a treat but I had to format a partion for FAT16. It may be that a later DOS version would handle FAT32.
