I made a different simple test and it hasn't worked.Yes if you put 12v 50-60hz on the secondary you'd get 240v on the primary, the regulation on a small trans would be poor, meaning the voltage would drop as soon as a load is connected, might be enough to drive a small fluorescent tube.
If you exceed the rated voltage primary or secondary the core would saturate, making the winding act more like a short circuit.
Yes, I used the green wires as the primary and connected them to the wall socket.You placed that as primary wiring to 230v side, and plugged that in photo in wall socket? Green wires were for primary)
If that's the case, Id say too much current and hence fuse blowed. Inrush current killed fuse.
And to my eye, such small wires look quite small for primary side in terms of insulation at least.
Of course, I will ask every single details before doing anything. Thank you for the advice.Indeed, mains voltage is very lethal, not it feels awful (well okay, I experienced only 120v....) but it can lead to burns, and possibly death through cardiac arrest in case mains current flows throught heart. (situation when heart pumps on mains frequency, 60hz) not to mention, you can't let go once you are hooked in mains voltage. You don't need to start fearing mains voltage, respect it and know what you really are doing.
Sounds MUCH more saferI will try to use 12 volts AC 0.3 amperes and see if happens the same. I have a transformer to step down 230 VAC to 12 VAC and the current output is 0.3 amperes, so using the output of the step down transformer as the primary energy source to feed the same toroid transformer, it should work. Right?
True.And since we're dealing with inductive resistance, what is your base of knowledge? (resistances are msinly divided in 3; resistive, purely resistive, like resistor, inductive, more inductive, like coil/transformer, and capacitive, like capacitor) Each behaves differently in ac/dc, except resistive, which is "same" all time.
Yes, of course. I didn't know that the setup would cause problems.Sounds MUCH more safer. I fear however that it causes too much load on transformer, you can attach as low as: ohms=volts/amperes->12v/0.3A=40ohms. (But, actual voltage can be as high as 1.414, or square of 2, times voltage,=1.414 x 12volts~16volts, but this was just an extra stuff here) Also, when transformer is unloaded, voltage on secondary is higher than what is said. The values you see are constant ratings, but it is not wise to keep load on maxinum)
What equipment do you have?
I have a small transformer with a laminated steel core. The configuration was similar to the setup I was trying, so I thought that using the toroid core would be very similar. But no.The toroid material is designed for high frequencies, not ideal for a mains 50 or 60 Hz transformer, which have a laminated steel core. The four turns on your toroid would be a dead short and take out the circuit breaker.
