paridhi jain
how to scale the 9V to 660mV.
yes, i m using voltage divider my resistor burn.
r2/r1 = 12/1
I take the output form r2
In addition to the questions JimB posted above, it would also be useful to know the current (I) requirements of your circuit and the power rating(s) of the resistors being used.yes, i m using voltage divider my resistor burn.
I don't why you want to get 0.660 volts.how to scale the 9V to 660mV.
If you need 0.66 volts to run a motor then that is a very different thing.
If you need 0.66 volts to drive a small meter then that is another thing.
i want to run small meter
i want to r[un a small meter]
