Just wanted to tell you to expect a nice video from me in about 20 minutes. Its only 1 5x7 brick but scrolls nicely including a POT to control the speed. All code was hand written... (Except FONT) heh
In get_element procedure, u can used keyword inc(y) instead of y++
Ur codes is Ok! But thank. That will will helped newbies.
ur codes is looked perfectly. The only thing u called is between top to void main
U should put one line by line not single line
If u do line by line, the microprocessor will executes faster then slower.
It is bad readable for readers
Can you show me a little example.
Here it is:
Congratulation, Atom!
How do u get speed control by using pot?
unsigned char GetADC(void){
unsigned int TempXY,TempD;
TempD = 0x03FF / 100;
ADCON0bits.GO = 1; //Start the conversion
while(ADCON0bits.DONE); //Wait until it’s done
TempXY = (int)(((int)ADRESH << 8)| ADRESL) / TempD;
return TempXY;
//.... I call like:
Addon = GetADC();
//.... I use value like
for(b=0;b<1+Addon;b++)
void ChkBtn(void){
if(UP){
Delay100TCYx(20);
while(UP);
if(Speed<95){
Speed++;
if(DOWN){
while(DOWN);
Delay100TCYx(20);
if(Speed>1){
Speed--;
LoadStr((unsigned rom char *)"AtomSoft@gmail.com");
SCROLL_LEN = strlen(StringBuff); //StringBuff is GLOBAL it contains a copy of the string above from LOADSTR
SCROLL_LEN = (SCROLL_LEN * 6)+30;
Speed = 20;
while(1){
for(n=0; n<SCROLL_LEN; n++){
for(b=0;b<Speed;b++){ //THIS IS WHERE SPEED FITS IN
ChkBtn();
for(m=0; m<16; m++){
if(((m+n) > (SCROLL_LEN-15)) || (m+n)<15){
COL = 0;
} else {
COL = Buffer[(n+m-15)];
CLK = 1;
Nop();Nop();
CLK = 0;
Delay100TCYx(25);//50
New 3 blocks:
YouTube - LED Matrix Test 3
Code:void ChkBtn(void){ if(UP){ Delay100TCYx(20); while(UP); if(Speed<95){ Speed++; } } if(DOWN){ while(DOWN); Delay100TCYx(20); if(Speed>1){ Speed--; } } }
The above is what checks the buttons...
Speed is a GLOBAL variable.
Code:LoadStr((unsigned rom char *)"AtomSoft@gmail.com"); SCROLL_LEN = strlen(StringBuff); //StringBuff is GLOBAL it contains a copy of the string above from LOADSTR SCROLL_LEN = (SCROLL_LEN * 6)+30; Speed = 20; while(1){ for(n=0; n<SCROLL_LEN; n++){ for(b=0;b<Speed;b++){ //THIS IS WHERE SPEED FITS IN ChkBtn(); for(m=0; m<16; m++){ if(((m+n) > (SCROLL_LEN-15)) || (m+n)<15){ COL = 0; } else { COL = Buffer[(n+m-15)]; } CLK = 1; Nop();Nop(); CLK = 0; Delay100TCYx(25);//50 } } } }
; Filename: *
; Date: *
; File Version: 001 *
; Author: Jason Lopez *
; Company: AtomSoft *
#include <p18f2525.h>
#include <delays.h>
#include <string.h>
#pragma config WDT = OFF, LVP = OFF, OSC = INTIO67, XINST = OFF
unsigned char GetADC(void);
void setSpeed(void);
unsigned char Addon=0;
Prototypes
unsigned rom char speedtest[18] ={
0x00, 0x7E, 0x11, 0x11, 0x11, 0x7E,
0x00, 0x7F, 0x49, 0x49, 0x49, 0x36,
0x00, 0x3E, 0x41, 0x41, 0x41, 0x22,
void main(void);
unsigned rom char Font[96][6] =
{ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00 }, // sp
{ 0x00, 0x00, 0x00, 0x2f, 0x00, 0x00 }, // !
{ 0x00, 0x00, 0x07, 0x00, 0x07, 0x00 }, // "
{ 0x00, 0x14, 0x7f, 0x14, 0x7f, 0x14 }, // #
{ 0x00, 0x24, 0x2a, 0x7f, 0x2a, 0x12 }, // $
{ 0x00, 0x23, 0x13, 0x08, 0x64, 0x62 }, // %
{ 0x00, 0x36, 0x49, 0x55, 0x22, 0x50 }, // &
{ 0x00, 0x00, 0x05, 0x03, 0x00, 0x00 }, // '
{ 0x00, 0x00, 0x1c, 0x22, 0x41, 0x00 }, // (
{ 0x00, 0x00, 0x41, 0x22, 0x1c, 0x00 }, // )
{ 0x00, 0x14, 0x08, 0x3E, 0x08, 0x14 }, // *
{ 0x00, 0x08, 0x08, 0x3E, 0x08, 0x08 }, // +
{ 0x00, 0x00, 0x00, 0x50, 0x30, 0x00 }, // ,
{ 0x00, 0x10, 0x10, 0x10, 0x10, 0x10 }, // -
{ 0x00, 0x00, 0x60, 0x60, 0x00, 0x00 }, // .
{ 0x00, 0x20, 0x10, 0x08, 0x04, 0x02 }, // /
{ 0x00, 0x3E, 0x51, 0x49, 0x45, 0x3E }, // 0
{ 0x00, 0x00, 0x42, 0x7F, 0x40, 0x00 }, // 1
{ 0x00, 0x42, 0x61, 0x51, 0x49, 0x46 }, // 2
{ 0x00, 0x21, 0x41, 0x45, 0x4B, 0x31 }, // 3
{ 0x00, 0x18, 0x14, 0x12, 0x7F, 0x10 }, // 4
{ 0x00, 0x27, 0x45, 0x45, 0x45, 0x39 }, // 5
{ 0x00, 0x3C, 0x4A, 0x49, 0x49, 0x30 }, // 6
{ 0x00, 0x01, 0x71, 0x09, 0x05, 0x03 }, // 7
{ 0x00, 0x36, 0x49, 0x49, 0x49, 0x36 }, // 8
{ 0x00, 0x06, 0x49, 0x49, 0x29, 0x1E }, // 9
{ 0x00, 0x00, 0x36, 0x36, 0x00, 0x00 }, // :
{ 0x00, 0x00, 0x56, 0x36, 0x00, 0x00 }, // ;
{ 0x00, 0x08, 0x14, 0x22, 0x41, 0x00 }, // <
{ 0x00, 0x14, 0x14, 0x14, 0x14, 0x14 }, // =
{ 0x00, 0x00, 0x41, 0x22, 0x14, 0x08 }, // >
{ 0x00, 0x02, 0x01, 0x51, 0x09, 0x06 }, // ?
{ 0x00, 0x32, 0x49, 0x59, 0x51, 0x3E }, // @
{ 0x00, 0x7E, 0x11, 0x11, 0x11, 0x7E }, // A
{ 0x00, 0x7F, 0x49, 0x49, 0x49, 0x36 }, // B
{ 0x00, 0x3E, 0x41, 0x41, 0x41, 0x22 }, // C
{ 0x00, 0x7F, 0x41, 0x41, 0x22, 0x1C }, // D
{ 0x00, 0x7F, 0x49, 0x49, 0x49, 0x41 }, // E
{ 0x00, 0x7F, 0x09, 0x09, 0x09, 0x01 }, // F
{ 0x00, 0x3E, 0x41, 0x49, 0x49, 0x7A }, // G
{ 0x00, 0x7F, 0x08, 0x08, 0x08, 0x7F }, // H
{ 0x00, 0x00, 0x41, 0x7F, 0x41, 0x00 }, // I
{ 0x00, 0x20, 0x40, 0x41, 0x3F, 0x01 }, // J
{ 0x00, 0x7F, 0x08, 0x14, 0x22, 0x41 }, // K
{ 0x00, 0x7F, 0x40, 0x40, 0x40, 0x40 }, // L
{ 0x00, 0x7F, 0x02, 0x0C, 0x02, 0x7F }, // M
{ 0x00, 0x7F, 0x04, 0x08, 0x10, 0x7F }, // N
{ 0x00, 0x3E, 0x41, 0x41, 0x41, 0x3E }, // O
{ 0x00, 0x7F, 0x09, 0x09, 0x09, 0x06 }, // P
{ 0x00, 0x3E, 0x41, 0x51, 0x21, 0x5E }, // Q
{ 0x00, 0x7F, 0x09, 0x19, 0x29, 0x46 }, // R
{ 0x00, 0x46, 0x49, 0x49, 0x49, 0x31 }, // S
{ 0x00, 0x01, 0x01, 0x7F, 0x01, 0x01 }, // T
{ 0x00, 0x3F, 0x40, 0x40, 0x40, 0x3F }, // U
{ 0x00, 0x1F, 0x20, 0x40, 0x20, 0x1F }, // V
{ 0x00, 0x3F, 0x40, 0x38, 0x40, 0x3F }, // W
{ 0x00, 0x63, 0x14, 0x08, 0x14, 0x63 }, // X
{ 0x00, 0x07, 0x08, 0x70, 0x08, 0x07 }, // Y
{ 0x00, 0x61, 0x51, 0x49, 0x45, 0x43 }, // Z
{ 0x00, 0x00, 0x7F, 0x41, 0x41, 0x00 }, // [
{ 0x00, 0x02, 0x04, 0x08, 0x10, 0x20 }, // back slash
{ 0x00, 0x00, 0x41, 0x41, 0x7f, 0x00 }, // ]
{ 0x00, 0x04, 0x02, 0x01, 0x02, 0x04 }, // ^
{ 0x00, 0x40, 0x40, 0x40, 0x40, 0x40 }, // _
{ 0x00, 0x00, 0x01, 0x02, 0x04, 0x00 }, // '
{ 0x00, 0x20, 0x54, 0x54, 0x54, 0x78 }, // a
{ 0x00, 0x7F, 0x48, 0x44, 0x44, 0x38 }, // b
{ 0x00, 0x38, 0x44, 0x44, 0x44, 0x20 }, // c
{ 0x00, 0x38, 0x44, 0x44, 0x48, 0x7F }, // d
{ 0x00, 0x38, 0x54, 0x54, 0x54, 0x18 }, // e
{ 0x00, 0x08, 0x7E, 0x09, 0x01, 0x02 }, // f
{ 0x00, 0x0C, 0x52, 0x52, 0x52, 0x3E }, // g
{ 0x00, 0x7F, 0x08, 0x04, 0x04, 0x78 }, // h
{ 0x00, 0x00, 0x44, 0x7D, 0x40, 0x00 }, // i
{ 0x00, 0x20, 0x40, 0x44, 0x3D, 0x00 }, // j
{ 0x00, 0x7F, 0x10, 0x28, 0x44, 0x00 }, // k
{ 0x00, 0x00, 0x41, 0x7F, 0x40, 0x00 }, // l
{ 0x00, 0x7C, 0x04, 0x18, 0x04, 0x78 }, // m
{ 0x00, 0x7C, 0x08, 0x04, 0x04, 0x78 }, // n
{ 0x00, 0x38, 0x44, 0x44, 0x44, 0x38 }, // o
{ 0x00, 0x7C, 0x14, 0x14, 0x14, 0x08 }, // p
{ 0x00, 0x08, 0x14, 0x14, 0x18, 0x7C }, // q
{ 0x00, 0x7C, 0x08, 0x04, 0x04, 0x08 }, // r
{ 0x00, 0x48, 0x54, 0x54, 0x54, 0x20 }, // s
{ 0x00, 0x04, 0x3F, 0x44, 0x40, 0x20 }, // t
{ 0x00, 0x3C, 0x40, 0x40, 0x20, 0x7C }, // u
{ 0x00, 0x1C, 0x20, 0x40, 0x20, 0x1C }, // v
{ 0x00, 0x3C, 0x40, 0x30, 0x40, 0x3C }, // w
{ 0x00, 0x44, 0x28, 0x10, 0x28, 0x44 }, // x
{ 0x00, 0x0C, 0x50, 0x50, 0x50, 0x3C }, // y
{ 0x00, 0x44, 0x64, 0x54, 0x4C, 0x44 }, // z
{ 0x00, 0x00, 0x08, 0x36, 0x41, 0x00 }, // {
{ 0x00, 0x00, 0x00, 0x7f, 0x00, 0x00 }, // |
{ 0x00, 0x00, 0x41, 0x36, 0x08, 0x00 }, // }
{ 0x00, 0x04, 0x02, 0x04, 0x08, 0x04 }, // ~
{ 0x00, 0x00, 0x00, 0x36, 0x00, 0x00 } // ¦
void LoadStr(unsigned rom char *string);
void ChkBtn(void);
unsigned char strLen;
unsigned char Buffer[120];
unsigned char StringBuff[20];
unsigned char Speed=0;
#define UP PORTAbits.RA1
#define DOWN PORTAbits.RA2
#define COL LATB
#define CLK LATCbits.LATC3
Main
void main(void){
unsigned char x,y,z,l;
unsigned char m,b;
unsigned int n;
unsigned char SCROLL_LEN = 0;
OSCCON=0x72; //8MHz clock
OSCTUNEbits.PLLEN=0; //disable PLL
while(!OSCCONbits.IOFS); //wait for osc stable
TRISA = TRISB = TRISC = 0;
LATA = LATB = LATC = 0;
TRISAbits.TRISA1 = 1;
TRISAbits.TRISA2 = 1;
ADCON0 = 1;
ADCON1 = 0x0F;
Speed = 20;
while(1){
ChkBtn();
COL = 0;
} else {
CLK = 1;
Nop();Nop();
CLK = 0;
void ChkBtn(void){
if(UP){
Delay100TCYx(20);
while(UP);
if(Speed<95){
Speed++;
if(DOWN){
while(DOWN);
Delay100TCYx(20);
if(Speed>1){
Speed--;
void LoadStr(unsigned rom char *string){
char x,y,z;
unsigned char temp = 0;
for(x=0;x<120;x++){
Buffer[x]=0;
for(x=0;x<20;x++){
StringBuff[x]=0;
y=0;
z=0;
while(*string){
StringBuff[z++]=*string;
for(x=0;x<6;x++){
temp = *string;
Buffer[y+x]=Font[(temp-0x20)][x];
string++;
y+=6;
