SDHC code
How are you intending to use the SDHC card? The protocol is protected IP, as a hobbyist you can only access the card using the SPI protocol. Google "sdhc spi", plenty of decent results.
Assuming SPI mode, then it's not all that different from regular SD. The library I'm using (FatFS) supports both and only has some minor logic changes if it sees SDHC. I haven't really looked at it in detail, but I know it works with my 4GB SDHC microSD.
Thanks I'll take a look at FatFS and google sdhc spi. I'm not sure if the init is different but so far with the code from petit fs no luck
Its not easy heh i cant get it to init at all! this is the code im trying to use:
DSTATUS disk_initialize (void)
    BYTE SDHC = 0;
    BYTE ocr[4] = {0,0,0,0};
    BYTE ty,cmd;
	WORD tmr;
    WORD r,i,x;
    tmr = 10000;
    r = 0;
    init_spi();
    // 1. with the card NOT selected
    DESELECT();
    // 2. send 80 clock cycles start up
    for ( i=0; i<10; i++)
        writeSPI(0xFF);
    // 3. now select the card
    SELECT();
    // 4. send a single RESET command
    r = send_cmd(CMD0, 0);
    //DESELECT();
    if ( r != 1)                // must return Idle
        return 1;   // comand rejected
    // 5. send repeatedly INIT until Idle terminates
    if (send_cmd(CMD8, 0x1AA) == 1) {	/* SDC ver 2.00 */
        SDHC = 1;
        i = 0;
        for (x = 0; x < 4; x++) ocr[x] = rcv_spi();
		if (ocr[2] == 0x01 && ocr[3] == 0xAA) {	                    /* The card can work at vdd range of 2.7-3.6V */
		    while (send_cmd(ACMD41, 1UL << 30)){	                /* ACMD41 with HCS bit */
                i++;
                if(i==tmr) break;
		    if (send_cmd(CMD58, 0) == 0) {	                        /* Check CCS bit */
			    ty = (ocr[0] & 0x40) ? CT_SD2|CT_BLOCK : CT_SD2;	/* SDv2 */
    }else{
        if (send_cmd(ACMD41, 0) <= 1) {
        	ty = CT_SD1;
            cmd = ACMD41;	/* SDv1 */
		} else {
			ty = CT_MMC;
            cmd = CMD1;	/* MMCv3 */
        for (i=0; i<tmr; i++){
            r = send_cmd(cmd, 0); DESELECT();
            if ( !r)
                break;
        if ( i == tmr)
            return 2;  // init timed out
            r = send_cmd(CMD16, 512); DESELECT();
            if ( r)
                break;
        if ( i == tmr)
	return r;
I made the above code from the below code:
static
DSTATUS MM_disk_initialize (void)
	BYTE n, ty, cmd, ocr[4];
	if (Stat[1] & STA_NODISK)			/* No card in the socket */
		return Stat[1];
	MM_power_on();						/* Force socket power ON */
	FCLK_SLOW();
	for (n = 10; n; n--) MM_rcvr_spi();	/* 80 dummy clocks */
	ty = 0;
	if (MM_send_cmd(CMD0, 0) == 1) {			/* Enter Idle state */
		Timer1 = 100;							/* Initialization timeout of 1000 msec */
		if (MM_send_cmd(CMD8, 0x1AA) == 1) {	/* SDC ver 2.00 */
			for (n = 0; n < 4; n++) ocr[n] = MM_rcvr_spi();
				while (Timer1 && MM_send_cmd(ACMD41, 1UL << 30));	/* ACMD41 with HCS bit */
				if (Timer1 && MM_send_cmd(CMD58, 0) == 0) {	/* Check CCS bit */
		} else {							/* SDv1 or MMCv3 */
			if (MM_send_cmd(ACMD41, 0) <= 1) {
				ty = CT_SD1; cmd = ACMD41;	/* SDv1 */
			} else {
				ty = CT_MMC; cmd = CMD1;	/* MMCv3 */
			while (Timer1 && MM_send_cmd(cmd, 0));	/* Wait for leaving idle state */
			if (!Timer1 || MM_send_cmd(CMD16, 512) != 0)	/* Select R/W block length */
				ty = 0;
	CardType = ty;
	MM_release_spi();
	if (ty) {			/* Initialization succeded */
		Stat[1] &= ~STA_NOINIT;		/* Clear STA_NOINIT */
		FCLK_FAST();
	} else {			/* Initialization failed */
		MM_power_off();
	return Stat[1];
FROM here:
i doubt it. I think it has SPI also. But not sure... i can sort of get it going but heh its a huge headache. So im going to take a break and move on to IR for cable using some captures from "DirtyLude" aka Mark.
Hopefully if i can get my IR to work on my cable box then its all progress heh
The SDHC isnt too much of a hassle but its easier for me to get SDHC cards at discount then SD non HC heh
The FatFS library's Init method is outlined on this page under "How to support SDC Ver2 and high capacity cards". They call SDHC SDC V2.
ELM - How to Use MMC/SDC
As far as I can see, looking through the code, there's no difference other than the Init.
heh i tried to init the as you can see from above code heh but no luck :( its not as easy and they make it. I know its my fault heh since everyone else gets it heh
Ill re write the whole thing tommorow without LCD code as to clear up my confusion heh
I'm reading on that chans site and I have to admit it doesn't seem so difficult heh. I am going to write my own code fully bitbanged SPI and custom init. And if all goes well I'll write a nice PDF explanation as to help others out . I think it will take me about 2-3 days since I work heh
Well, here's the initialization code from FatFS if it helps. This is one thing I have no problem keeping as a black box, though.
for (n = 10; n; n--) rcvr_spi();	/* 80 dummy clocks */
ty = 0;
if (send_cmd(CMD0, 0) == 1) {			/* Enter Idle state */
	if (send_cmd(CMD8, 0x1AA) == 1) {	/* SDHC */
		for (n = 0; n < 4; n++) ocr[n] = rcvr_spi();		/* Get trailing return value of R7 resp */
			while (Timer1-- && send_cmd(ACMD41, 1UL << 30));	/* Wait for leaving idle state (ACMD41 with HCS bit) */
			if (Timer1 && send_cmd(CMD58, 0) == 0) {		/* Check CCS bit in the OCR */
				ty = (ocr[0] & 0x40) ? 12 : 4;
	} else {							/* SDSC or MMC */
			ty = 2; cmd = ACMD41;	/* SDSC */
		} else {
			ty = 1; cmd = CMD1;		/* MMC */
		while (Timer1-- && send_cmd(cmd, 0));			/* Wait for leaving idle state */
		if (!Timer1 || send_cmd(CMD16, 512) != 0)	/* Set R/W block length to 512 */
			ty = 0;
CardType = ty;
release_spi();
Some what good with bad news lol
Got the SD to init ok i assume since it passes ! but i found out where it get stuck. Its stuck on mounting. it retruns NO FILESYSTEM when i know 100% there is one heh..
FRESULT pf_mount (
	FATFS *fs		/* Pointer to new file system object (NULL: Unmount) */
	BYTE fmt, buf[36];
	DWORD bsect, fsize, tsect, mclst;
    BYTE res;
	FatFs = 0;
	if (!fs) return FR_OK;				/* Unregister fs object */
    res = disk_initialize();
	if (res & STA_NOINIT)	/* Check if the drive is ready or not */
		return FR_NOT_READY;
	/* Search FAT partition on the drive */
	bsect = 0;
	fmt = check_fs(buf, bsect);			/* Check sector 0 as an SFD format */
	if (fmt == 1) {						/* Not an FAT boot record, it may be FDISK format */
		/* Check a partition listed in top of the partition table */
		if (disk_readp(buf, bsect, MBR_Table, 16)) {	/* 1st partition entry */
			fmt = 3;
		} else {
			if (buf[4]) {					/* Is the partition existing? */
				bsect = LD_DWORD(&buf[8]);	/* Partition offset in LBA */
				fmt = check_fs(buf, bsect);	/* Check the partition */
	if (fmt == 3) return FR_DISK_ERR;
[B][COLOR="Red"]	if (fmt) return FR_NO_FILESYSTEM;	/* No valid FAT patition is found */[/COLOR][/B]
	/* Initialize the file system object */
	if (disk_readp(buf, bsect, 13, sizeof(buf))) return FR_DISK_ERR;
	fsize = LD_WORD(buf+BPB_FATSz16-13);				/* Number of sectors per FAT */
	if (!fsize) fsize = LD_DWORD(buf+BPB_FATSz32-13);
	fsize *= buf[BPB_NumFATs-13];						/* Number of sectors in FAT area */
	fs->fatbase = bsect + LD_WORD(buf+BPB_RsvdSecCnt-13); /* FAT start sector (lba) */
	fs->csize = buf[BPB_SecPerClus-13];					/* Number of sectors per cluster */
	fs->n_rootdir = LD_WORD(buf+BPB_RootEntCnt-13);		/* Nmuber of root directory entries */
	tsect = LD_WORD(buf+BPB_TotSec16-13);				/* Number of sectors on the file system */
	if (!tsect) tsect = LD_DWORD(buf+BPB_TotSec32-13);
	mclst = (tsect						/* Last cluster# + 1 */
		- LD_WORD(buf+BPB_RsvdSecCnt-13) - fsize - fs->n_rootdir / 16
		) / fs->csize + 2;
	fs->max_clust = (CLUST)mclst;
	fmt = FS_FAT12;							/* Determine the FAT sub type */
	if (mclst >= 0xFF7) fmt = FS_FAT16;		/* Number of clusters >= 0xFF5 */
	if (mclst >= 0xFFF7)					/* Number of clusters >= 0xFFF5 */
#if _FS_FAT32
		fmt = FS_FAT32;
#else
#endif
	fs->fs_type = fmt;		/* FAT sub-type */
#if _FS_FAT32
	if (fmt == FS_FAT32)
		fs->dirbase = LD_DWORD(buf+(BPB_RootClus-13));	/* Root directory start cluster */
	else
#endif
		fs->dirbase = fs->fatbase + fsize;				/* Root directory start sector (lba) */
	fs->database = fs->fatbase + fsize + fs->n_rootdir / 16;	/* Data start sector (lba) */
	fs->flag = 0;
	FatFs = fs;
	return FR_OK;
why me!?!?!? heh
anyway im off to work. Ill be back later on.. If anyone can figure out why im stuck feel free to share... here is my code attached below...
  • sd.zip
The SD and SDHC interface specification is not really controlled IP. The spec that tells you how to design your own card (for card manufacturers) that one costs $1k.
But you can get and read the interface spec freely here:
That spec has everything you need to know for accessing SD and SDHC cards via 4-bit/1-bit SD bus or in SPI-mode.
OMG heh i think i got it heh
I forgot to add 1 line to init (in red BOLD):
    BYTE SDHC = 0;
    BYTE ty,cmd;
	WORD tmr;
    WORD r,i,x;
    tmr = 10000;
    r = 0;
	ty = 0;
    init_spi();
    DESELECT();
        writeSPI(0xFF);
    SELECT();
    //DESELECT();
    if (send_cmd(CMD8, 0x1AA) == 1) {	//* SDC ver 2.00
        SDHC = 1;
        i = 0;
		if (ocr[2] == 0x01 && ocr[3] == 0xAA) {	                    //* The card can work at vdd range of 2.7-3.6V
                r = send_cmd(ACMD41, 1UL << 30);
                DESELECT();
                if (!r)
                    break;
		    if (send_cmd(CMD58, 0) == 0) {	                        // Check CCS bit
			    ty = (ocr[0] & 0x40) ? CT_SD2|CT_BLOCK : CT_SD2;	// SDv2
    }else{
        	ty = CT_SD1;
            cmd = ACMD41;	//* SDv1
		} else {
			ty = CT_MMC;
            cmd = CMD1;	//* MMCv3
            if ( !r)
                break;
        if ( i == tmr)
[B][COLOR="Red"]    CardType = ty;[/COLOR][/B]
	return r;
This is why it was so usefull: (inside disk_readp)
	if (!(CardType & CT_BLOCK)) lba *= 512;		// Convert to byte address if needed
Converts LBA to BLOCKs or something
Finally got my camera working heh:
2GB CARD:
2gb-jpg.35438
4GB CARD:
4gb-jpg.35439
Nice! You're an inspiration!
Let us know when you get LongFileName implemented...
thanks
i wouldnt use LFN on a PIC mainly because heh it takes up enough memory already heh....
i might try to get the FATFFS Working on this tho. WHIch has it already i think
thanKS again
