Sealed Lead-Acid battery discharge limit?
elecfriend
I am using sealed Lead acid battery 12V, 2.3AH. If battery low circuit is NOT used, it discharges as low as 3V. Is it harmful? should I use low limit protection circuit? if yes, then upto what level?
Hi elecfriend,
a 12V SLA-battery is as dead as it can be if it discharges to 3V. :(
The very low limit is 1.8V per cell, 10.8V total for a 12V battery.
Hi elecfriend,
An Automotive starting battery is permanently damaged and will have to be replaced if discharged below 11V (1.8V per cell); a "deep-cycle" battery shouldn't routinely be discharged below 10.8V, otherwise life will be shortened.
I know and that's why I wrote "very low limit".
I told you before, your 12V battery is knackered if it's discharged to 3V.
Send it away for recycling and buy a new one. Don't dispose of lead acid batteries in the household waste, they contain lead which is bad for the environment.
The minimum discharge voltage will be on the datasheet.
