Serial comm between uC and PC...
For storing string array is working correct.
while(1)                        // endless Loop
ch='a';
HSerout(ch);//for testing uart is working
   for(char t=0;t<6;t++){
    c[t]= HSerin();
for(char t=0;t<5;t++) {
ch=c[t];
    HSerout(ch); //sending back the data
But using pointer are not displaying back the data ....
ch='a';
    *c++= HSerin();
ch=*c++;
The pointer keeps incrementing and never returns to the beginning of the array. When you use indexing, the loop always starts from the beginning of the array. The code where you use pointer starts always from the point where it left the last time.
This always starts from index 0 and loops through 0...4.
C:
ch=c[t];
In this code, the pointer c keeps on incrementing every time the loop is executed..
C:
ch=*c++;
Why don't you just use indexing?
Leave optimization to the compiler. Usually when a programmer starts "optimizing" his code, he actually makes it worse. Writing good readable code produces much better results most of the time. Modern compilers are very good at optimizing code...
OK, just leave but anyway how to read or point to initial the pointer to read string??
You need to re-define the pointer every time before going into the loop. You need an extra variable for that.
char *temp;
temp = c;
ch=*temp++;
another way is to "rewind" the pointer to the original position after the loop:
ch=*c++;
c = c-4;
char *temp;
temp = ch;
ch=*temp++;
OK you are copying......
I added comments to the code:
char *temp; // Temporary pointer that we will use inside the loop.
temp = c; // Set the pointer at the beginning
ch=*temp++; // Increment the pointer and get the character from that position
