Series Diode Input Impedance???
Space Varmint
Off hand does anyone know the approximate input impedance of a series input 1N914 with a 10K ohm resistor connected to the back end going to ground? I want to use a step transformer to feed it.
Look at this graph, you should be able to figure out the resistance at different forward currents.
Yes, use Ohm's law.
Also note that it's dependant on the temperature, current and that it varies between diodes with the same part number: look at the difference between the typical and maximum vales, the minimum values aren't specified and the difference is probably going to be as great.
