hi,I want to drive a LED with a 555 timer.
I want the LED to toggle each 100ms.
How do I pick the resistor and capacitor to set a rectangle wave at a frequency of (1/200m)Hz?
Thanks.
Thank you Eric.
I'm not sure, what website can this calculator be downloaded from?
Thanks.
Hi Eric.
Thanks again.
Would this configuration work? Having the LED toggling every 100ms.
(Vs would be 5V, and I'll connect LED + (Current limiting) Resistor to pin #3 - OUT).
What is VC (Pin #5) connected to?
I assume its a capacitor, but what kind of a capacitor?
A calculator is no substitute for reading the **broken link removed**. The bypass cap is described there.
It is recommended that you download the Datasheet for the device from www.datasheetarchive.com
Ensure that your designs are within the stated operating parameters of the device.
hi Mike,
This text is shown on my modules.
hi RV,hi,
that was a good application. Was that done by U?
i want to know where i could get those kind of applications for diff. ICs
Specifically IC4060
hi RV,Ok, So can i simulate using LT Spice?
Is it inbuilt/ should i design the circuit?
I'm asking this because I've not experimented LT Spice.
hi RV,
I did write that module and others using Visual Basic 5.
If you want to simulate some logic IC's there is always LTspice, I have not seen an 4060 model, but it could quickly emulated using the basic LTS models.
Hi D,He means simulated. Drink some coffee, Eric![]()
Emulation is the imitation of an object as another object. For example, a PlayStation emulator makes PlayStation game CDs recognize a PC as the machine where they are intended to run. Another example, a man puts on fake breasts, wear woman clothing and soften his voice to emulate a woman. So, basically an emulation has a purpose to make its environment recognize an object as another object. This is why emulator needs to be complete. If, for example, the man emulating a woman fails to emulate a woman completely like urinating while standing, he will be found out not to be a woman. About emulator, you usually says: "I want to make this stuff be recognized as that stuff so that another thing that I have in mind will continue to interact with the emulated stuff in the way it interacts with the real stuff".
Hi D,
No, 'emulate' is the word I would use, my reasoning is that he will have to use 'other' types of logic IC's to emulate the 4060 in the LTS simulation.
QED.
Hope you are rested after your brief holiday..![]()
Really? Why is that? What other types of logic IC's would he use? I've never simulated logic in LTspice before. Maybe I should give it a try.
Now I see what I've been doing wrong!![]()
HA! Well, anyone and everyone is an author these days![]()
