shape logic of analog differeratiator and integrator
yefj
Hello ,I am use to see differentiator and iintegrator from a perspective of pulse input.
Integrator turns pulse into ramp because its accumilating.
differtiator turns pulse into two spike because its mathematics.
In the circuit below I have RC integrator and differentiators.
Is the some mathematical intution regarding the differentiator that could explain why given the following input I have such shape on output V(b)?
Thanks.
update:
V(A) is a integrator.the input is a ramp .integrator result always rises as the input non zero. why the integrator result of V(a) gets platoe?
Integrates into the supply rail limitations. Eg. Vout cannot exceed OpAmp supply rail V. In'
this case Voltage rail limit.
The "integrator" is not an integrator - there is a resistor across the capacitor.
The two resistors form s voltage divider of roughly 6:1 so the capacitor can never charge beyond roughly 1/7th the supply voltage.
Note that a passive R-C integrator will not give linear results as the rate of change varies with the existing capacitor voltage, for a fixed input voltage. You need to use an opamp based integrator for to work well.
