Hi folks,
My Shop Vac bearings began to squeal lately.
I decided to take it apart and grease them.
The Repair certainly seem to go well, I hand cranked the electric motor prior to the fix with the noise, and then it was quiet after the lubrication.
I made note of all parts as I removed them and kept components together.
When I put the Fan assembly back together, I noticed that it did not tighten down on the motor shaft.
The only explanation I can think of is that there was a sleeve on the shaft that held the fan assembly off of the plastic housing that the Motor is attached to.
Has anyone taken apart their Shop Vac ?
Did you notice an additional bearing or sleeve on the motor shaft used to keep the fan suspended ?
Derek
I really should have taken pictures during the tear down process.
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Derek
