Space Varmint
Hi, I cannot find the pin out for a Shure mike model # 444. All the pdf's are other stuff about them but can't get pin out.
I used my scope to check it and it looks like if I run pin 7 to the center pin then pin 5 will be ground and pin 6 is mike output using PTT button. Just want to make sure. If anybody knows of a spec. sheet, it would be greatly appreciated.
Also, I would like to use a VFO for a receiver to create an SSB output signal to be amplified. If anyone has experience using SSB, then you know that you can be bitched at for being off frequency. I do not want to use one of my IFs for various reasons. Does anyone have a suggestion on using the VFO (1st LO) to produce the output frequency?
I will use some examples:
Let's say I am using 10Mhz as the 1st IF and IF Xtal filter. So on the receiver I would be running the VFO at 17MHz to receive 7MHz.
So I need a carrier frequency to run into my ballanced modulator along with the audio to produce a double sideband output. At that point I think I will mix it with something, then filter it. So I need another mixer to mix with the VFO freq. I need a good scheme so I will transmit right on my receive freq.
Any suggestions?
Any suggestions?
