......also in that first diagram i am using led's to represent the DC motor and i will be limiting the bases after i fig out which transistors ill be using, usually the 2n3055,
hi D,..... also even if i do use an op amp am having problems when i put a full wave rectifier in it seems to filter the negative signal voltage
