Hi! I have a beeeg problem here.
Please kind enough to go through the pictures drawn down here.
When I apply A sinusoidal to that ferrite rod from a KENWOOD signal generator, my system works properly. but I have to use my own signal generator for the final system. I designed a one and It worked well. But the problem is when I apply it to the rod, the voltage drops.
I decided that the low reactant of the coil may be the reason. But why did it work with the signal generator? What shall I do to this problem? I'll update my test results. Please give some comments. (If you no anything about 8038 ICs,pls share that also)
