Hello.
I am new to this chat, so I hope this is the right forum to post to.
I have the idea to use a 555 to build a small triggered timer with an 'after release' delay. I have been google-ing but can not find the right schematic/design that looks to work for me, so I will try this forum![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Case is this:
I will be using this in my car. I have 2 batteries in the car and I have 2 individual voltmeters, 1 for each battery.
1. I want the voltmeters to turn on (double pole relay for that) when I start the car, and stay on for ~45 seconds after I turn off the car.
2. I also want to be able to check the battery status with a button (momentary on) without starting the car (same relay).
3. Plus I have a button (momentary on) for start-assist (intelligent battery combiner relay with 30 sec start-assist) so that this will also be a trigger for the voltmeters (30 sec start-assist + ~10-15 sec extra on time), (also same relay).
4. All other time the output of the 555 should be off.
As stated I will be using this in my car, so Vcc and input/trigger is 12v ~+.
I have the 3 different input triggers separated with diodes.
The circuit will be more or less always on, running of the extra battery.
I hope this is understandable and you get my point...
I can not figure out how to do this so that there is both the constant on time and a delay after the release of the input/trigger... maybe some combination between trigger, threshold, discharge and reset...? So here I need the help of some wiser people![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks a lot in advance,
Kingo
Case is this:
Kingo
