circuitnoob
I fixed a electret microphone to it but there seems to be no sound when i speak. is there something wrong with the circuit diagram or something wrong with my circuit....???
It is a terrible circuit.I fixed a electret microphone to it but there seems to be no sound when i speak. is there something wrong with the circuit diagram or something wrong with my circuit....???
I never tried one and I didn't measure the inductance of my simple air coils but they work.can i use an 100nH axial inductor instead of an air coil for the LC tank?
This circuit is a simple two transistor (2N2222) FM transmitter. No license is required for this transmitter according to FCC regulations regarding wireless microphones. If powered by a 9 volt battery and used with an antenna no longer than 12 inches, the transmitter will be within the FCC limits. The microphone is amplified by Q1. Q2, C5, and L1 form an oscillator that operates in the 80 to 130 MHz range. The oscillator is voltage controlled, so it is modulated by the audio signal that is applied to the base of Q2. R6 limits the input to the RF section, and it's value can be adjusted as necessary to limit the volume of the input. L1 and C6 can be made with wire and a pencil. The inductor (L1) is made by winding two pieces of 24 gauge insulated wire, laid side by side, around a pencil six times. Remove the coil you have formed and unscrew the two coils apart from each other. One of these coils (the better looking of the two) will be used in the tank circuit, and the other can be used in the next one you build. The antenna (24 gauge wire) should be soldered to the coil you made, about 2 turns up from the bottom, on the transistor side, and should be 8-12 inches long. To make C6, take a 4 inch piece of 24 gauge insulated wire, bend it over double and, beginning 1/2" from the open end, twist the wire as if you were forming a rope. When
you have about 1"
this circuits is really unstable,i have build it,it dosent works good!
There are about 150 FM transmitter projects on the internet. The coil in them is almost the same. 5 to 9 turns of wire.so.. you're one lucky fellow?
I don't know which FM transmitter circuit you are talking about.i like this circuit but could you tell me what is the frequency of operation of this circuit . And what are the calculation related to this circuit..
I don't know which circuit you built. If you made it on a breadboard then the high capacitance of all the wires and between all the conductive contacts make it not work. Make it on a compact pcb.I don't understand how to make capacitor 6 and cant get the circuit to work. Pleas post the theory.
Your English is horrible.i want to a design of Simple FM transmitter(by electroMaster). How calculate value of R1,R2,R3,R4,R5? help me? I'm doing project of circus. reply soon.
mail: dinhkli245@yahoo.com
thaks inf.
