I have a requirement to generate around 100V at 1.5A into a resistive load from a 14.4V LiFePO4 pack (rated at 60A continuous).
I've tried a couple of 600W and 1200W eBay off the shelf boost converters but they:
a) fall a bit short on voltage, typically 80V max.
b) have a maximum *input* current limit of 10 - 15A maximum continuous which limits power a bit.
c) are a bit bulky, bearing in mind this is for a portable application.
(but those converters worked just fine to trickle charge my 72V ebike battery from 12V in my car)
Since I'm only running power into a ceramic-cased heating element, I don't need much in the way of regulation or even mind if it is ac or dc output. A very quick check of the sealed element shows that it has a low inductance, so it shouldn't mind a reasonably high frequency.
I'd wondered about a beefed up version of a power blocking oscillator (a giant Joule Thief) based on a mosfet and ferrite torroid. As it happens, my junk box has a stack of IRBF4110 power mosfets (used to repair ebike controllers) and some 40mm or so torroids of the same sort as the eBay converters. Since those fets have a maximum operating voltage of 100V, I'm assuming I'd need to put a secondary winding on the torroid to step up to safely achieve my 100 or so Volts output.
Anyone have thoughts on a minimum parts count way of doing this, before I warm up the soldering iron and blow up a few components?
