Simple Radio control circuit knowledge needed please !!!!!!!!!!
tundejnr
I have a project where I have to remotely turn on a circuit which will power a motor from about 100m away, I just need some help starting off, because of the simple on/off task i not sure if i need a circuit with a microchip and if a simple transmitter receiver pair with do the job in my project.
Please help!!!!!!!!!!!!
As you can probably tell this is definitely not my area of expertises
How about something like this? It has momentary outputs, but you can generate a toggle with an added FF such as the 4013.
If you want one button to turn the motor on and another button to turn it off then connect the Set FF input to one channel and the Reset FF input to another.
The receiver or FF output will need to drive a solid-state or mechanical relay to control the motor.
You will need a 5VDC power supply for the receiver, which could be supplied by a regulated wall-wart such as this.
