Simple thermostat circuit to control seed propagator
Jules
I have a heated propagator inside a greenhouse to aid seed germination (5Watt 240V). There is no way of controlling its temp. I need a simple thermistor thermostat circuit to switch heating on when air temp falls in evening, and switch heating off when air temp rises. I want to run this circuit from a simple capacitative mains dropper power supply, so it doesn't need transformer or batteries.
Any help please? Thanks
thermostat for propagator
Very little space or cash for transformer. I do have a lot of mains dropper caps though. I was thinking of a Triac to conrol the mains supply.
Any ideas?
Have a look at , the 'Auto-Fan' should do what you want.
But, in my opinion, if you have to ask for something as simple as a thermostat you shouldn't be messing with live mains and capacitive droppers!.
Pardon me can i ask ,re that fan circuit. could you take the relay
out and directly control a PC Fan? the one i have is rated as;
12VDC
input current 0.08A
power 0.69W
if i changed R1, P1 and TH1 round would it then work in reverse. (if its hot it turns on, when its cool it turns off)
Regards
Fenris
